Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
1993 dodge stealth transmition jumps when put in revers
Old Feb 15, 2011 | 10:56 AM
javicu91's Avatar
javicu91
Default 1993 dodge stealth transmition jumps when put in revers
Ok so I have a 1993 dodge stealth and my transmission jumps every time I put it into revers gear from park this started happening after the transmission oil pressure sensor was replaced need help anybody know how to fix this
Old Feb 23, 2011 | 11:55 AM
Girly TT's Avatar
Girly TT
You mean the engine oil pressure sender unit?
There is no trans oil pressure sensor...
Did you change the trans fluid? If so, did you check the level? And HOW did you check the level? The trans fluid needs to get hot, run through the gears, and be in neutral with the car ON to check the trans fluid level properly. You may be low on fluid.
