Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
91 Stealth SOHC runs rough & stalls
Old Apr 10, 2011 | 02:19 PM
mytyme68's Avatar
mytyme68
Default 91 Stealth SOHC runs rough & stalls
Here's what I've got:
1991 Stealth SOHC runs very rough with low loping idle for a minute or two and than stalls out, it may do this a few times than eventually the engine just cranks and no restart. An hour or so later you can repeat the same senerio. Any help is much appreciated.
Thanks
Mark
Old Apr 12, 2011 | 10:49 AM
Girly TT's Avatar
Girly TT
is the MAF plugged in?
Old Apr 12, 2011 | 03:24 PM
mytyme68's Avatar
mytyme68
Yes, this happened a few weeks ago was able to limp the car back home. If you hold it above idle it will run but you can hear it pop in exhaust and smell the rotten egg smell.
Old Apr 13, 2011 | 12:15 PM
Girly TT's Avatar
Girly TT
Then your ecu is most like bad. Leaking capacitor. You need to either get the ecu rebuilt( if it can be), or buy a replacement one.
