Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Checking engine warning codes on Stealth
Old Jul 1, 2005 | 06:58 PM
Stelaro's Avatar
Stelaro
Default Checking engine warning codes on Stealth
When the check engine light is on, how do you guys with stealths check for the code? iv jumped the ALDL terminals on my camaro, but i dont know if it will be the same. im assuming it will blink the light, i knwo how to read that and all. also, anyone have a link or somthing to somewhere that shows what the codes stand for?
thanks a lot for any help
Old Jul 1, 2005 | 07:00 PM
Stelaro's Avatar
Stelaro
Default RE: Checking engine warning codes on Stealth
cant believe i find my own answer only minutes after posting it. i went to the general tech board and it says there, sorry
Old Jul 17, 2005 | 06:08 PM
Stelaro's Avatar
Stelaro
something must be different for stealths, i cant get the codes displayed by the way it explained in the gen tech section.
So... How do you check service engine codes on a stealth?
iv heard to turn the key ON, OFF, ON, OFF, ON within 5 seconds. But thats not working. are there connections that cant be jumped to get the light to display??
Old Jul 18, 2005 | 12:58 PM
thestealth's Avatar
thestealth
You have to check engine codes on a Stealth with an analog meter via the fuse box diagnostics port. Here are instructions. You'll have to research Stealth316 deeper to find out what the needle deflections mean. This should get you on the right path anyway.
edit: I found the page on Stealth316 that has what the error codes are. LINKY LINKY
Old Oct 14, 2005 | 06:01 PM
chiefshoe's Avatar
chiefshoe
Ok need some info on the fuel system
If I hotwire the fuel pump it will run?
What sends the signal to turn off pump?
MFI Relay?
ECM??
