Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
1993 dodge stealth problems
Old May 14, 2011 | 07:44 PM
tgraeter's Avatar
tgraeter
Default 1993 dodge stealth problems
i have a 93 stealth and i just replaced the head gaskets and tried to start it up and its shooting coolant out of a high pressure line and maybe under the thermostat? im not sure what the problem is. also i think the timing is just alittle off. please help!!!!!! ive put too much money and time into this car to let it go to waste.
Old May 16, 2011 | 05:08 PM
Girly TT's Avatar
Girly TT
find where the leaks is coming from, and either fix it, or replace the part... I am not sure what kind of help you are looking for with that?? Find the leak, and fix it.
Why do you think the timing is off?
Old Sep 27, 2011 | 07:26 PM
Lorirory's Avatar
Lorirory
I would not try to ajust the timing, first thing you need to check your themostat and gaskets to find your leak, that is probaly causing your car to run ruff shooting water and sucking air, good luck
Old Sep 28, 2011 | 12:05 PM
Girly TT's Avatar
Girly TT
holy thread resurrection.
