Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
93 stealth tranny
Old Aug 17, 2011 | 08:35 PM
stunnaeins's Avatar
stunnaeins
Default 93 stealth tranny
my 93 stealth 3.0 auto is in gear and wont move. was wondering if anyone has had this problem before. wondering if it would be tranny problem or tcu problem.
Old Aug 17, 2011 | 10:45 PM
Hans_GZP's Avatar
Hans_GZP
If you are in drive and it won't move anywhere, nor will it shift, then it's usually a bad torque converter or trans oil pump. You can pull a trans cooler line off of the trans and have someone turn on the car to see if fluid squirts out. If it does, then it's most likely your torque converter or really burnt up clutches.
