Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Stealth R/T Engine Wiring Harness Question "Plz Reply"
Old Sep 28, 2011 | 03:42 PM
jvm3s's Avatar
jvm3s
Default Stealth R/T Engine Wiring Harness Question "Plz Reply"
I am swapping out my base model 3.0v-6 Sohc to an Dohc 24v 3.0 r/t, my question is with the engine wire harness. Is the engine wire harness for my Sohc able to be used in conjunction with my dohc r/t motor? or will I need to find an r/t engine wiring harness? The harness for the r/t motor was chopped. thankyou for your response.
Old Sep 28, 2011 | 08:19 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I moved this thread to the Stealth section,
FF
Old Sep 29, 2011 | 11:37 AM
Girly TT's Avatar
Girly TT
No. You will need the DOHC wiring harness and ECU from the corresponding year DOHC car. You will also need all of the DOHC accessories. It is not a direct drop-in engine swap.
