Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Engine noise
Old Oct 23, 2011 | 12:32 AM
Maelthras's Avatar
Maelthras
Default Engine noise
I had just bought a 92 dodge stealth es, and drove 400 miles problem free, and then bam. I think it just spun a bearing, the sound is persistant at idle and sounds like, well a bearing spinning around loose inside the engine. The sound coincides with the speed of the engine and is constant. It runs and theres no engine lights on, so what do I do and where can I get a replacement engine if it is a spun bearing.
Old Oct 23, 2011 | 09:15 AM
Hans_GZP's Avatar
Hans_GZP
Where are you located?
Old Oct 23, 2011 | 11:20 AM
Maelthras's Avatar
Maelthras
Northern minnesota.
Old Oct 23, 2011 | 01:48 PM
Hans_GZP's Avatar
Hans_GZP
Are you sure it's a spun bearing and not some bad lifter tick? Usually a spun bearing won't start making noise unless the rpms are higher (say above 2500 rpms). It will eventually make noise at lower rpms, but it would have to be driven on for a while before that happens.
Old Oct 23, 2011 | 02:49 PM
Maelthras's Avatar
Maelthras
I seem to think it was just a very bad lifter tick. Video included. http://www.youtube.com/watch?v=hUVUT4XWKcw
Now after a minute of running I revved it to 4k and then the tick went away it seems. Video. http://www.youtube.com/watch?v=STJagOOZkiI
Old Oct 23, 2011 | 04:54 PM
Hans_GZP's Avatar
Hans_GZP
Take a video of the engine running and you pulling on the throttle cable. Also, how is the oil pressure looking? I would suggest changing the engine oil with something maybe slightly thicker than what might be in there. Also, check the drained oil for any copper flecks in it.
