Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
91 R/T with...
Old Dec 6, 2011 | 12:37 AM
ChanR/T91's Avatar
ChanR/T91
Default 91 R/T with...
34k on engine
130k on body
short ram intake
new exhaust
Problems:
when shifting from 1st to 2nd it grinds unless i shift at extremely low rpms. Every other gear shifts perfectly fine and when i still grind because i didnt wait long enough between shifts the check engine light sometimes comes on.
What should i try to fix this?
It has nice power to around 75mph but what helps achieve more pull or acceleration beyond 75mph?
Old Dec 6, 2011 | 04:31 PM
Hans_GZP's Avatar
Hans_GZP
Sounds like you need a Trans rebuild. Check engine light problem would require a scanner or voltmeter to read what code it's throwing. It may store it into the ecu.
Old Dec 6, 2011 | 11:18 PM
ChanR/T91's Avatar
ChanR/T91
Dam, are you sure? The gear shifting sound is only in second and the check engine light comes and goes periodically. I was told it may be the linkage. Is there anything i can try to do to get rid of the sound before facing the fact of a tranny rebuilt?
Old Dec 7, 2011 | 07:34 AM
Hans_GZP's Avatar
Hans_GZP
You can try a fluid change, but the damage is already done. If its grinding already, you will need a new gear, syncro, and slider assembly. Probably $250 in parts plus the labor to do it. The rest of the syncro rings are about $20 each, so I would replace them as well.
Old Dec 8, 2011 | 02:50 PM
ChanR/T91's Avatar
ChanR/T91
Ok thanks for your help... I thought the cost would be worse, how long of a fix do you think it is? Although, I am praying for it to be something minor because the sound isn't as much as a grind sound as i thought...its a very odd sound that doesn't sound damaging. I wish you could hear it.
