Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
91 rt boost
Old Jan 3, 2012 | 04:07 PM
drk_stealth91's Avatar
drk_stealth91
Default 91 rt boost
hey guys, am looking to raise the boost on my stealth and am wondering what is the max boost pressure it can take, its got no mods, 100% stock only think i want to do to it is boost the pressure a little and maybee an axhaust!!
Old Jan 4, 2012 | 09:50 AM
Girly TT's Avatar
Girly TT
14psi
Old Jan 4, 2012 | 08:02 PM
drk_stealth91
thanx
Old Jan 9, 2012 | 05:03 AM
WICK3DST3ALTH's Avatar
WICK3DST3ALTH
Unhappy problem
got a problem with tha 91 stealth rt tt, a vac line is off coming from the boost solenoid but idk where it goes its tha top one with tha white lines on it but it has a brass fitting in the end. and the car is making a knocking noise in the back head. doesnt really seem 2 phase it any tho. my friend has a 3000 gt that does the same thing only non turbo anyone have a clue? im thinking valve problem.
Old Jan 11, 2012 | 07:40 PM
Hans_GZP's Avatar
Hans_GZP
That vacuum line goes to the rear turbo intake pipe.
Old Mar 15, 2013 | 09:52 PM
1armyguy's Avatar
1armyguy
anyone have a schematic for the vacuum lines? just had the timing belt, water pump, crank sprocket and tensioners replaced and the did some of the vacume lines and not it seems like the boost just isn't working right. You can hear them boost up and watch the guage jump up but, the power just isn't there. One of the lines was routed in between the back heat shield and the O2 sensor and burnt right though it. It's the one that has some piece attached that has an adjustable dial on it and say out on one side. Any input would be a GREAT help.
Thanks,
Wayne
Old Mar 30, 2013 | 01:41 AM
toddrs93's Avatar
toddrs93
Attached
