Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
turbocharger
Old Sep 18, 2005 | 01:42 PM
spyderjunke's Avatar
spyderjunke
Default turbocharger
is this a bolt on trubocharger for a sohc base dodge stealth http://store.extrememotorsports.com/...cfm/4,1012.htm , will it work for my enigne , is this all i need to turbo charger my 1993 stealth, also do you guys think i shold buy a dohc engine from http://www.asapmotors.com/used-mitsu...nsmissions.htm for 795.00 , all i would need to make my engine a dohc is the engine right.
Old Sep 19, 2005 | 11:56 AM
thestealth's Avatar
thestealth
Default RE: turbocharger
You need much more than "just" turbos. You would need exhaust manifolds, oil pan (or have your modified for oil lines), motor mounts, a turbo ECU and wiring harness (not totally required, but makes tuning much easier), intercooler(s) and all the applicable piping. You are looking at a couple of thousand dollars just in parts (depending upon where you get them) plus labor expenses.
I don't have any experience with ASAPmotors so I can't help you there. The DOHC motor for a 91-93 is $1295 I have heard horror stories about importing motors, but like I said, I have no personal experience with any of them.
Yes, that is all you would need to make your car a DOHC. I'm not sure if the ECU and wiring harness is the same though, you would have to check on that.
