Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
oil pressure drops when clutch is engaged
Old Apr 21, 2013 | 06:29 PM
gidget39's Avatar
gidget39
Default oil pressure drops when clutch is engaged
I have a 94 stealth and every time i push in the clutch the oil pressure drops then climbs back up back up when i release the clutch .... any suggestions?
Old Apr 21, 2013 | 06:30 PM
gidget39's Avatar
gidget39
Oil pressure
Old Apr 22, 2013 | 11:33 AM
toddrs93's Avatar
toddrs93
Nothing to worry about. It's probably from a dip in rpms that cause a momentary drop in voltage to the gauges and slows the engine down. Main thing with oil psi is that it needs to rise when you step on the gas.
Old Apr 24, 2013 | 03:36 PM
gidget39's Avatar
gidget39
Thanks
