Sport and Tour lights bilnk at the same time
Hi, I'd like to know if any of you guys know what could be causing the tour and sport lights to be blinking at the same time on my 92' stealth. Since the car started doing that, it feels as if the suspension is in sport mode and I kept pushing the electronic suspension switch, but it wont do anything. Could it be a snesor??? lose wire??
It could be a couple of things. Look under the strut caps and make sure it is not a loose wire on top of the strut. The cap says "do not put on hand or parts"
something was lost in the translation.
If all 4 of those check out, it could be leaky capacitors on the ECS computer. This unit is located on the passenger side rear hatch behind a square cover. You will need to remove the tool tray next to the spare tire to access it. Leaky capacitors on the ECS computer can cause irrepairable failure to your ECU if left unchecked.
You should at least check those items, it's a start.
