Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Bad Stealth, no ecu
Old Aug 14, 2013 | 07:55 PM
91stlthexpmntl's Avatar
91stlthexpmntl
Angry Bad Stealth, no ecu
Got a 92 RT dirt cheap. I know this car was running well for previous owner, he hit a speed bump a little fast and the car died, cranks fine, but will not fire. Ecu has tested good, but has no pulse when tested in the car from the diagnostic connector. What would cause the electrical to fail after a hard bump. Anyone have any ideas. Does anyone know where I can get a decent wiring schematic for a 92 Stealth RT. Ummmm, HELP!!! PLEASE
Old Aug 15, 2013 | 10:38 PM
go-part's Avatar
go-part
Former Vendor
Check your ignition control module, it may have gotten disconnected.
http://www.stealth316.com/2-ignitionsystem.htm
http://www.rockauto.com/catalog/x,ca...0L%2BV6%2BDOHC
Wiring Diagram
http://www.autozone.com/autozone/rep...rGuideMain.jsp
Old Sep 14, 2013 | 03:46 PM
91stlthexpmntl
Ignition control module is fine, tested in my other stealth. The engine is out of a 93 3000 GT, tested the connections to the TDC sensor and the CAS sensor and checked the rewiring that was done, I found that to be correct. It seems as though the portions of the ecu are not fuctioning due to a bad connection or lack of power to the system. I am currently back probing the ecu to attempt to find the problem. Thanks for the info, Go-Part
