Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
new stealth new starting problem
Old Nov 26, 2005 | 04:12 PM
chiefshoe's Avatar
chiefshoe
Default new stealth new starting problem
I fix one for a buddy and he sends me a friend you all help last time lets see if you can do it again.
Ok I have replaced the ECU and the PTU and Ignition coil check out but I still cant get spark. when cranking the PTU wire looses voltage?? So it has to be a sensor not sending the right signal to the ECM any ideas?
Jim
Old Nov 27, 2005 | 02:46 PM
thestealth's Avatar
thestealth
Default RE: new stealth new starting problem
There should be 3 "hot" wires at the PTU and the ground. The 3 different wires carry the signal from the ECU to PTU. Each wire controls a coil pack (pair). Are you not getting spark on one pack or are all three not firing?? What year car is it?? I'm assuming it is a DOHC engine. About the only thing that sends signals to the ECU are the MAS and CAS (crank angle sensor).
Old Nov 28, 2005 | 05:41 PM
chiefshoe's Avatar
chiefshoe
found it the MFI relay was grounding out proble fixed engine runs like a champ.
