Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Check engine light - injector code
Old Jun 6, 2022 | 09:10 PM
JackO91's Avatar
JackO91
Default Check engine light - injector code
I have a '91' R/T TT. Several years ago I had severe running issues with it. In the process of trying to figure out what the problem was, I sent the injectors out twice to two different companies for cleaning. They came back both times in spec., but the check engine light has remained on ever since. The code reads #14, injector, harness/connector, and/or injector /coil resistance. The car runs fine; if the injectors or harness were defective, that wouldn't be the case. Code description is included below. So I'm stumped, any help will be greatly appreciated.
Thanks,
Jack
