Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
major transmission issue!
Old Jan 10, 2006 | 03:49 AM
Jtroy917's Avatar
Jtroy917
Default major transmission issue!
buddy o mine got a 92 stealth r/t FWD........tranny went bad 1st time..stayed in 3rd gear....but we got it fixed....then 2nd tranny went bad..and just died..wouldnt go in gear or anything...so we gotthat replaced....3rd tranny blew again....and we're about to go for a 4th...and be like WTF???......i have no clue....its like it keeps blowing every couple months.....it drives us nutz....any idea what the problem may be????....
and it also blows a huge cloud of white smoke when starting the car...revvin'.....and steppin on the gas.......i need major help peeps....
Old Jan 10, 2006 | 04:02 AM
philthebreaker's Avatar
philthebreaker
Default RE: major transmission issue!
ok so yeah i am his friend and he is talking about my car... i also have a few questions..... i mean the guy that has rebuilt it hs rebuilt it 2 times he is about to do it a third time... well he told me that he is going to check it out from top to bottom and if it has been abused he is not going to rebuild it, i mean i dont abuse it other than getting it up to 130 twice i drive it to and from work ... so yeah and i dont know what else about it other than i need a paint job and windo tent if any one could hook me up let me know... also if any one is willing to make some money i would like to get my engine rebuilt with a twin turbo put on... so let me know what ya'll know ...
Old Jan 10, 2006 | 12:57 PM
thestealth's Avatar
thestealth
Automatic tranny??
As for the smoke, more than likely it is the valve stem seals, but it could be the rings. Have you done a compression check??
Old Jan 10, 2006 | 02:55 PM
falcon66's Avatar
falcon66
Pure white smoke usually indicates coolant getting into cumbustion (blown head gaskets, possible leakage in head or cracked block). If the smoke has a blue tint it is usually oil (valve stem seals, rings, or again a blown head gasket). If you're not familiar with engines and troubleshooting them I would take it to someone who is.
Old Jan 16, 2006 | 01:38 PM
john123123's Avatar
john123123
Is your tranny a manual or automatic? As far as the smoke,warm your car up then take a look at the coolant overflow tank and look for bubbles. The 2 times that I have needed head gaskets(2 Dodge Spirits)there was white smoke and bubbles. Hope this helps. John
Old Jan 18, 2006 | 03:42 PM
Jtroy917's Avatar
Jtroy917
its an automatic tranny, and thanks for all the help
Old Jan 26, 2006 | 12:13 AM
jakster's Avatar
jakster
Automatic OK first off the guy who is rebuilding it may be a bad transmission guy. Not a bad mechanic just not a good transmission guy. If the tranny has blown three times it may have a wharped case. I have a guy in New Mexico who is a transmission specialist and he tells me about this stuff he rebuilds transmission that work. Allot of modern transmissions have alloy cases and the heat causes the housing to wharp. So no matter how many times you rebuild them they fail because the parts wear out in a few hundred miles. Sounds like this guy needs to go back to school on late model transmissions. the wrong fluid will kill a Mitsubishi transmission also.
