Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Custom Exhaust
Old Mar 15, 2006 | 07:42 PM
metal_militia_01's Avatar
metal_militia_01
Default Custom Exhaust
Im thinking about goin next week to get a custom exhaust put on and re tipped... removing the catalytic converter and gettin a glasspack put in any holes patched up and new tips(since one is missing)........
should i go with a bigger downpipe?????? any suggestions that would improve HP??
Old Mar 15, 2006 | 09:14 PM
1994shadowman's Avatar
1994shadowman
Default RE: Custom Exhaust
taking out the cat can give you more power, is your exhaust mandrel bent?, if not get mandrel bent pipes.
Old Mar 16, 2006 | 02:41 PM
thestealth's Avatar
thestealth
This is the route I would go...3SX performance headers...or scroll down for their downpipe. 3sx makes quality parts for these cars.
Removing the catalytic converter will give you good gains too, at the expense of emisions (you will fail an emissions test, so be sure you live in a state that does not require them.)
If you change your cat-back exhaust, DO NOT remover the resonator/premuffler, as it is not a restriction and prevents the exhaust from "droning" at highway speeds (RPM's). Mandrel bent is the best you can get if you go custom. You don't really want to but much more than 2 1/2" exhaust on your car. Going bigger will give you more power at the top of the powerband, but you will lose low end grunt.
Old Mar 16, 2006 | 05:28 PM
metal_militia_01
2 1/2 inch wont effect the volume of my exhaust will it? i dont want nothing loud but to keep the same sound i have now.... or more of a cat back exhaust sound...
Old Mar 16, 2006 | 05:40 PM
thestealth's Avatar
thestealth
Offhand...I think stock exhaust tubing size is 2 1/4.
Edited for clarification: Any change you make you your exhaust system WILL change the way it sounds, from removing the cat., to a new downpipe/headers, to a cat back exhaust set up.
