Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Changing spark plugs/wires...
Old Jul 6, 2006 | 02:12 AM
Fiery Red XIII's Avatar
Fiery Red XIII
Default Changing spark plugs/wires...
Plan on going w/dbl platinum plugs that meet Dodge specs, also will add a 3sx performance plenum spacer and tell you how that works! Do wires make a big diff? I was looking at plain or OEM wires versus racing wires.
http://www.partsamerica.com/ProductD...e=5004&ptset=A
this is an example of race wires...just checking if the wires wld be better/worse if you know?!? All this maint. will be done by July's end! Thanks all!
Red
Old Jul 6, 2006 | 04:35 PM
thestealth's Avatar
thestealth
Default RE: Changing spark plugs/wires...
On a stock/nearly stock NA, wires won't make that much of a difference. Some good 8.5mm wires should suffice just fine.
