1991 ES erratic miss
I was wondering if anyone has had this problem? After testing the entire ignition system and installing a rebuilt ecm the egine misses eratically when you give it gas. I've used a stethascope and listened to each injector and at idle they click normally utill you give it gas then they're all over the place. A noid light test gives the same result with iconsistent bright and dull flashes. End of the rope , Sean
Is the Crank Angle Sensor working properly??
I'm not really that familiar with troubleshooting injectors, but if all the injectors are mis-firing, there has to be another problem than 6 faulty injectors. More info about our fuel injection system, courtesy of Stealth316.
