NA fuel economy...PWR vs ECO switch
Subscribe
Aug 11, 2006 | 02:16 PM
I have a '94 R/T non turbo auto-tranny...I get right around 20 mpg w/the switch on Economy mode...does any1 know how much gas mileage is affected by switching it to power mode/leaving it there? Also, I know this causes shifts to occurr at higher RPM's. Is it bad to leave it in PWR mode? Thanks!
Red
Reply 0
Aug 11, 2006 | 03:55 PM
RE: NA fuel economy...PWR vs ECO switch
I have the exact same car as you. I honestly have not noticed a huge fuel economy difference between power and economy mode. I keep mine on power because I like the way it shifts - you can definitely tell a difference and the car just feels faster. Right now I have been getting about 21-22 MPG in power mode. About 90% of the miles I drive every day are highway miles.
Reply 0
Aug 11, 2006 | 03:59 PM
I get 20mpg in the pwr mode. I don't think I've ever used the eco mode for any length of time.
Reply 0
Aug 11, 2006 | 06:27 PM
Cool! Thanx guys! Also, when I do have it in Power mode, sometimes when it shifts, a belt will squeal very briefly...no slipping or problems shifting that I can feel...any ideas as to which belt/why? Does it around 6500 rpms or so.
Red
Reply 0
Aug 11, 2006 | 08:41 PM
One of your belts is probably just a little bit loose, or in need of changing. Don't overtighten it though, or you run the risk of premature wearing of the bearing on your accessories/tensioners.
Reply 0
Aug 21, 2006 | 11:45 AM
I just finished calculating average MPG in power mode. This average is city and highway driving with most of the miles being highway. The A/C was on for 1/2 the time. I went 390 miles on 17.055 gallons. I averaged 22.867 MPG. Hope this helps someone!
I will be calculating average MPG in economy mode this week, so I will post my results for that very soon.
Reply 0
Aug 21, 2006 | 08:25 PM
this is good to read...ive been woundering if i should keep it on power mode or not....since you guys havent noticed much of a difference in gas millage i may leave it on power all the time.
quick question, whats overdrive for and do you keep it on or off?
Reply 0
Aug 21, 2006 | 10:13 PM
StealthRT94 -
Overdrive is your 4th gear. Sometimes I leave mine off for city driving. Always leave it on for highway driving.
Reply 0
Aug 27, 2006 | 11:09 PM
Just finished testing MPG on economy mode. I went 434 miles on 18.041 gallons. Average MPG was 24.056. I guess there is a slight improvement using eco mode, but I personally like pwr mode better. Take care every1!!
Kevin
Reply 0
Aug 27, 2006 | 11:36 PM
Not bad! Only 40 miles/tank difference. Thanks for the tests!!
Red
Reply 0
