Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Transaxle Lock.... Help!
Old Aug 17, 2006 | 06:27 AM
sandwichshop420's Avatar
sandwichshop420
Default Transaxle Lock.... Help!
I have a 1991 Dodge Stealth with a transaxle issue. It is an automatic transmission with the standard Front Wheel Drive. When it is hooked up to a diagnostic computer it displays the error transaxle lock. When driving the car it drives fine, but only in 3rd gear. Park, Neutral and Reverse are all fine. But when put in Drive, 2nd or Low gear it pulls away in third and stays in third. Just looking for any ideas I can try before looking for a new transmission or having it rebuilt. Please help!
Old Aug 17, 2006 | 11:19 AM
Carcharodont's Avatar
Carcharodont
Default RE: Transaxle Lock.... Help!
I'd take the console inside the car apart and see if you see anything ajar, a loose cable assembly or anything, and tighten it if that's the case. Other than that, take it to a place that either specializes in transmission repair or take it to the dealership to have them look at the tranny.
Old Aug 17, 2006 | 12:08 PM
thestealth's Avatar
thestealth
Sounds like it is in the "limp mode." It could be an internal failure or a problem with the TCU (tranny control unit).
Old Aug 18, 2006 | 06:17 AM
EvilZombieZ's Avatar
EvilZombieZ
Same thing happened to my car and all I did was replaced the TCU and it was fixed right now.
