Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Idle problem fixed
Old Aug 22, 2006 | 11:20 AM
INDYSTEALTH's Avatar
INDYSTEALTH
Default Idle problem fixed
Well finally some good news! For those having idle problems this may help... (Thanks to 'thestealth'). I took off the IAC and cleaned it and the throttle body that was exposed after taking the IAC off. There were several ports in this area that were filled with black crap. The STP cleaner took care of it thought less than $3. I went ahead and changed the air filter too. Be careful when cleaning the IAC not to get the coils wet. I dont know, but Im sure it wouldnt work well if you applied current to them with them wet.
Now all I need is a couple of window operators. If anyone knows where to get these a decent price, let me know.
Old Aug 22, 2006 | 12:51 PM
thestealth's Avatar
thestealth
Default RE: Idle problem fixed
I thought 3sxperformance sold the window regulators, but since they updated their site I cannot find them. I know the dealer will sell them, give Rockville Mitsu a call, they have as good of prices for OEM parts as I have found. Did you check any local auto parts stores?
Old Aug 22, 2006 | 05:22 PM
91Stealth's Avatar
91Stealth
What exactly did you use to clean out the IAC, my check engine light was on with my old IAC in and when i changed it my light stays off but my idle is still rough, could the problem be i changed the IAC and didn't clean out the port, I am stumped on my idle problem, looking for any help!!
Old Aug 23, 2006 | 03:05 PM
falcon66's Avatar
falcon66
You can get a spray can of carb and throttle body cleaner from any parts store or Wal-Mart. Remove your intake tube from the throttle body and the IAC. The spray will clean out the gunk easily enough. If that does not work check for air leaks (disconnected, deteriorated or damaged tubes). There is off the shelf fuel injector cleaner though I'm not sure how effective they are. If you try them, use it on a full tank of gas without making any of the other changes to see if by the end of the tank you see any improvement.
I know it's frustrating but by making ony one change at a time you can better identify what actually corrected the problem. Good luck!
Old Aug 23, 2006 | 03:35 PM
91Stealth's Avatar
91Stealth
Can you spray the carb and throttle body cleaner righ inside the port where the IAC is?
Old Aug 23, 2006 | 05:20 PM
falcon66's Avatar
falcon66
The Carb cleaner is made so it will not harm your engine. It is kind of like spraying gas into your intake. If your engine is running it will momentarily bogg down due to the air/fuel ratio being screwed up but it clears quickly. I have used it all the time when rebuilding carburators and cleaning fouled throttle bodies.
Old Aug 24, 2006 | 01:40 AM
whitey97's Avatar
whitey97
yup, it's a pretty common problem. i know i've offered that as advice to a few different people as well
