Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Why is it limp?
Old Oct 15, 2006 | 03:21 AM
wolf50000's Avatar
wolf50000
Default Why is it limp?
Hey guys, I'm brand new to the list, but I've had my Stealth for over 9 years. Still love it too.
I'll get to my question right away. My clutch pedal started feeling funny (like it was limp) so I checked the reserve tank and saw that it was empty. I went to the store and filled it up with clutch fluid, but nothing happened! The clutch still feels the same, and the fluid has not lowered one bit. Do I have to pump the clutch a bunch of times? Is there a bleeder valve? Is there air in the lines? Are there two reservoirs?
Thanks. I have had no problems with my car for 9 years. One water pump replaced, and that's it. Good luck and a good car!
Ryan
Old Oct 15, 2006 | 01:21 PM
thestealth's Avatar
thestealth
Default RE: Why is it limp?
Yes, you probably have air in your lines. Here is a procedure for bleeding a hydralic clutch. If your car is not turbo, it will be a little different, because you do not have the vacuum resivoir. Courtesy of Stealth316
