Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Problem with IAC
Old Nov 4, 2006 | 06:42 PM
91Stealth's Avatar
91Stealth
Default Problem with IAC
I had an old IAC that needed to be replaced. a buddy of mine had just bought a used engine from japan from a car there (less than 50,000 miles on it) and he gave me the IAC out of that engine. Put the IAC in my car, ran fine for a couple minutes, then when the car warmed up,it sputtered then it died. Now i just checked the resistance of the pins and they were all 39.8 or so except for pins 4 and 5. they were 4 ohms but 5 and 6 were still 39.8..... Is there something else with the car that can cause premature failure of the IAC or was it just a bad IAC when I got it. Can it be cleaned up on the inside to fix this problem, or is it shot?
Old Nov 4, 2006 | 06:44 PM
91Stealth's Avatar
91Stealth
Default RE: Problem with IAC
Sorry, i forgot to tell you, my car is a 91 stealth R/T NA and the new IAC was from a japanese Mitsubishi 3 liter. Same as whats in the stealth.
Old Nov 6, 2006 | 02:55 PM
thestealth's Avatar
thestealth
I would say that it is more than likely bad. If one of the coils showed a low resistance, it will not work properly. It was probably bad from the start.
Old Nov 8, 2006 | 05:10 PM
falcon66's Avatar
falcon66
Short circuits in wiring or the ECM may cause the IAC to burn out.
Old Dec 5, 2006 | 12:08 AM
91Stealth's Avatar
91Stealth
I have no check engine light but is there a way i could tell if my car is shorting out the IAC. i don't want to buy the 200 dollar part , put it in and short it out... is there a way to test the voltage of the connector that connects to the IAC unit to see it one is bad or sumthing.. ANY suggestions are appreciated... also... i needed to put in a new engine temp sensor.. no one had one.. napa had a sensor for 91 thru 96 mitsubish.. same connector but it was a "LITTLE" different. screwed in ok, doesn't leak and car still runs but when i first put it in i got a light, disconnected the battery for a minute and then the light dissappeared and no more light... what was the deal with that..?
Old Dec 5, 2006 | 12:10 AM
91Stealth's Avatar
91Stealth
also.. the engine temp sensor was to the computer.. it wasn't to the gage...
Old Dec 6, 2006 | 12:27 AM
91Stealth's Avatar
91Stealth
Can anyone help me out..?? PLZ!
also will both of these fit.. one is 144 bucks the other is 151bucks. I want the 151 dollar one but its not exactly like the one in my car. I did search vehicle specific.
Heres the link-
http://www.autopartsgiant.com/CAT_FRAMEX.cfm
