Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
anybody know how to replace a water pump?
Old Jan 4, 2007 | 10:39 PM
ts20racing's Avatar
ts20racing
Default anybody know how to replace a water pump?
hey, i just baught a 92 stealth but it has a bad leak coming from the water pump. Does anybody know how to replace it or knows of a website that can tell me??????
Old Jan 4, 2007 | 11:19 PM
thestealth's Avatar
thestealth
Default RE: anybody know how to replace a water pump?
Search for Stealth316. Somewhere on that site is probably a detailed procedure for doing it. You should go ahead and replace the tbelt, idler, tensioners while you are there. It is quite a labor intensive job, before you start it, I highly recommend picking up a service manual from 3SX performance. It will help bunches. You will need a large "puller," to remove the crank pulley, the drivers side motor mount has to come off, all the plastic covers will need removed. Setting the timing can be a pain, make sure you have it at TDC before you release tension on the tbelt. You should wire the cam pulleys together, or fabricate some kind of blocks to keep them from moving once tension is released. It is not a hard job, yet it is not easy either.
Old Jan 6, 2007 | 03:15 PM
ts20racing's Avatar
ts20racing
thanks!! i looked on 3sxperformance.com for a munual but couldn't find one. will i have to go to the shop to pic one up?
Old Jan 7, 2007 | 02:00 PM
thestealth's Avatar
thestealth
http://www.3sx.com/store/comersus_vi...idProduct=1281
Here is a link to the manual.
ORIGINAL: ts20racing
