Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
95 Stealth Auto transmission help
Old Jan 7, 2007 | 01:25 AM
GreenHornet95's Avatar
GreenHornet95
Default 95 Stealth Auto transmission help
About a year ago the transmission seemed to shift into neutral when the overdrive engaged. So I turned off the overdrive and the problem went away. But now it is acting up again. Now when I hit about 40 mph or more the transmissionslips into neutral until the car reaches 5 to 10 mph and it down shifts to 1st gear. All this happened when the shifter was in the drive position. However, I was able to drive it back to my house with the shifter in 2nd gear, never pushing it above 40mph.
Could this possibly a bad TCU or ECU, or is my tranny hosed?
Old Jan 7, 2007 | 01:53 AM
OhioBlueStealth's Avatar
OhioBlueStealth
Default RE: 95 Stealth Auto transmission help
I have the same exact problem myself except it will run upfine with theoverdrive off.Me and my father think its just a bad cellinoid... i'm getting it fixed hopefully within the next month. To get a transmission cheak its usuallyabout 80$ ... and if it is just a bad cellinoid it will cost anywhere from 200$ up to about 500$
Old Jan 7, 2007 | 05:04 PM
GreenHornet95
Thanks for your response. We will look into that!
Old Feb 1, 2007 | 10:56 PM
stealth29032's Avatar
stealth29032
IPT performance trans sells an end clutch rebuild kit for $84 and www.myplymouthlaser.com has a very detailed how to with pics on installing the parts pretty simple to do
