Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
I need some help guys
Old Jan 21, 2007 | 03:34 PM
LuvmyStealth's Avatar
LuvmyStealth
Default I need some help guys
I'm blowing my TPS fuse if I'm not gentle with the clutch....any ideas?
Old Jan 22, 2007 | 05:27 PM
falcon66's Avatar
falcon66
Default RE: I need some help guys
Short Circuit? Sorry![&:]
Old Jan 22, 2007 | 06:24 PM
thestealth's Avatar
thestealth
What he said. You have to have a short somewhere in the wiring. Good luck. Wiring gremlins can be the hardest to find.
Old Jan 22, 2007 | 07:26 PM
LuvmyStealth
Thanks guys! I was wrong with my 1st post it's the ECI blowing. I was told that the TPS needed replaced.(nothing tested, was just a guess) I was guessing that it was the wiring.
Old Jan 22, 2007 | 08:55 PM
thestealth's Avatar
thestealth
Do you mean your ECU?
There is either a wire somehow came loose and you are hitting it with the clutch pedal assembly, or the clutch switch is shorted/bad. Do you ever have trouble starting the car?
Old Jan 22, 2007 | 09:21 PM
LuvmyStealth
No..It's the ECI fuse. The only problem starting the car is the dead battery. It's a new battery but for some reason it keeps dying on me.
Old Jan 23, 2007 | 12:32 PM
thestealth's Avatar
thestealth
You must have a dead short somewhere.
