98 stratus, high idle 3000rpm help
Old Sep 5, 2004 | 01:34 PM
ckman's Avatar
ckman
Default 98 stratus, high idle 3000rpm help
Hey all, Just replaced the headgasket and all associated with that. Finished up and started the car and went for a drive. Came back to flush the cooling system and ever since the the car idle'd at 3000 rpm. It didnt do that during the drive first off. Disconnected the battery for the night, and let it sit. tried agian this morning, and it started at 2000 rpm, but it is quickly rising, i assume as the engine warms up. I pulled the tps wire and no change, throttle body is closed well and not hung up on anything. Throttle cable is not hung up either nor the cruise control. Anyone seen this happen and know the fix would be awesome.
Thanks
