Won't start
Old Apr 18, 2007 | 11:30 AM
thermite_rocks's Avatar
thermite_rocks
Default Won't start
My parents '96 strat 2.4L won't start but cranks fine. Dad replaced the spark plugs but not
the wires. He says they are fine. He just passed inspection/emission in PA in February.
The 'check engine light' codes = 5,5 test over nothing detected. It has about 119K miles.
I suggested he atleast try a new set of wires before having it towed to his favorite local shop
but he doesn't agree.
Old Apr 19, 2007 | 04:03 AM
H.P.fanatic13's Avatar
H.P.fanatic13
Default RE: Won't start
When mine wouldn't start I had to just change the battery. Thank god. But mine wasn't cranking hell it wasn't doing anything. every now and then it would try but to no avail. But yeah I just changed my battery and I haven't had a problem since. so its just a thought but you might want to check that out first. your battery might have a bad cell but still enough charge to crank it. It would be cheaper then towing to a shop and them telling you that you need a battery.
Old Apr 19, 2007 | 01:29 PM
voltork's Avatar
voltork
Check for spark before replacing the wires. Just pull a plug rest it on the block and watch as you turn the car over, there should be a nice 1/4 inch blue spark, just DON'T touch the plug or wires while its turning over, it hurts.... Bad experiences there...
Old Apr 20, 2007 | 01:25 PM
01indigoR/T's Avatar
01indigoR/T
when he first turned the key did he hear the fuel pump running? should make a humming sound for maybe half a sec or so. if he didnt hear anything then thats the problem, not getting any fuel. its a common problem on cars with that many miles on it. hope this helps
