will these tires fit OK
Old May 13, 2007 | 12:50 PM
patcal's Avatar
patcal
Default will these tires fit OK
The stock 195/70-14 tires on my 96 Breeze are pretty close to being done. I can get a mounted set of 205/70-14 for about $125. Will these fit OK? The diameter is larger obviously. Any thoughts on this? Thanks.
Pat Callaghan
Portland, OR.
96 Breeze
Old Jun 16, 2007 | 11:43 AM
Kissmyne's Avatar
Kissmyne
Default RE: will these tires fit OK
They should fit.. .I'd check how close your current tires get to your suspension, wheel wells and fenders... also if your tires rub when turning to the lock.. Then I wouldn't recommend it... unless you get wheel spacers or the like...
