Timing belt tension pully
Old Jun 10, 2007 | 03:02 AM
wormdad's Avatar
wormdad
Default Timing belt tension pully
I have a 98 stratus that the bolt on the timing belt tensioner pully has broken off. Is the area that it bolts up to part of the block or can it be taken off and how?
Old Jun 10, 2007 | 05:58 AM
tomthedog's Avatar
tomthedog
Default RE: Timing belt tension pully
helps i fyou gove the eng type and size. 4 cly (2.0/2.4L) or 6 cly (2.5/2.7L). my haynes don'thave good pic's.what were you trying to do? was it the bolt that went through thr pully or themounting bolt? let us know.
Old Jun 10, 2007 | 12:16 PM
tacoboy's Avatar
tacoboy
I have a 97 2.0 and the pulley bolt mates with the bracket which mounts to the block with 3 bolts. Is this pulley boltthe bolt you are referring to?
