Need to bleed clutch on my '02 stratus rt
Old Jun 14, 2007 | 07:58 PM
MJ BARR's Avatar
MJ BARR
Default Need to bleed clutch on my '02 stratus rt
Can anyone tell me where the plug is to bleed the clutch on my Stratus RT 5 Speed?
Old Jun 14, 2007 | 09:30 PM
autoguru77's Avatar
autoguru77
Default RE: Need to bleed clutch on my '02 stratus rt
There should be a bleeder screw on the slave cylinder on the trans. Did you replace the master/slave cylinders or line?
Old Jun 15, 2007 | 10:14 AM
MJ BARR's Avatar
MJ BARR
Can not find bleeder on slave cylinder. Slave cylinder may have been replaced. Don't know, first time seeing this vehicle. Any suggestions?
Old Jun 15, 2007 | 04:38 PM
autoguru77's Avatar
autoguru77
Just wondering why your bleeding the clutch? If it is getting air in it then that should be repaired first. inspect the lines for any leaks-pull back the rubber boot and inspect for leak in slave cylinder-check firewall under hood as well as under dash where the rod goes through for any sign of leak.Hydraulic clutches shouldn't need to be bled unless the system is opened up.
