chirping noise in transmission
Old Jun 21, 2007 | 04:51 AM
JoshD's Avatar
JoshD
Default chirping noise in transmission
Hi all. i have an '02 dodge stratus with 45k miles. today, after driving home from work, i noticed a slight chirping noise coming from under the hood.it sounds like a bird, thats the best way that i can describe it. the noise is only there when the transmission is in gear. i am not quite sure what may be causing this, but any help would be much appreciated. thank you in advance.
Old Jun 22, 2007 | 08:42 PM
Dodge Tech's Avatar
Dodge Tech
Default RE: chirping noise in transmission
have some one be outside under the hood and put it in drive it could be the belts are worn or not tight and when u put a load on it they chirp or yeha it could be something inside the tranny.
