sparks plugs
Old Oct 21, 2004 | 11:13 PM
bandit96's Avatar
bandit96
Default sparks plugs
i just bought a set of NGK Iridium plugs for my 02 stratus 2.4L, and when i compared the stock to the new, the ngk were much longer than stock. I think the stock ones are 14mm and the ngk are 24mm, will this cause any harm to the motor???
Old Nov 7, 2004 | 01:14 PM
josh4rim's Avatar
josh4rim
Default RE: sparks plugs
If they fit it shouldnt, but make sure the are not touching any "hot" areas or you will be buying a new set.
