stratus 98 fuse #5 keeps blowing at high RPM
I've recently bought a stratus 98 4cylinder 2.0 liters manual. this car had a known issue of blowing fuse #5 pcm/automatic shutdown relay @ rpms more than 3750. After it blows the fuse all the neadles on the gauges freeze till ignition is off, though the lights stay on. After replacing a blown fuse car starts like usual. also radio volume while driving jumps up and down at times .
brought it to the garage and mechanic could not take a reading from the computer. suggested me to change pcm and come back. Alhtough when i start the car all the proper dashboard lights come on and then go offas if computer opeates properly. I checked relays and sockets with multimeter. readings were withing specification; also checked wires and connections for visible damage- nothing there either.
i also noticed that idle rpm is @ 750 , don't know if it is normal.
i think the problem is not a computer or not only a computer and i'm afraid to change this expensive piece just to fry another one right away.
Anybody had similar problem ? Any suggestions, please ?
Update
disconnected alternator and could get to 6 mil RPM without blowing a fuse. Engine works really fine, so the problem is located.
will update again when it's solved
