problems with engine
Old Nov 10, 2007 | 09:06 AM
wendykey's Avatar
wendykey
Default problems with engine
I recently bought a 2002 stratus from my sister since I thought I had an idea how to fix it. The dealership is giving me the run around so maybe someone here can help me. The dash is spitting out two codes, P1684 and P0700 which is the transmission control system malfunction and the metering oil pump position sensor circuit malfunction. When I call the parts place, no one knows what I am talking about. Does anyone here have a similiar problem? And does any one have a picture of the engine where these sensors are located? It would be greatly appreciated!
Old Nov 10, 2007 | 12:03 PM
nate_0022's Avatar
nate_0022
Default RE: problems with engine
The only oil pump sensor I know is, is located right above the oil filter, but that's for the oil pressure.
Old Nov 10, 2007 | 11:19 PM
Sixtysixdeuce's Avatar
Sixtysixdeuce
O700 tells you there is a trans problem, 1684 is that trans problem. The MOP position sensor is in the transmission solenoid pack.
