02 R/T Transmission question
Old Nov 17, 2007 | 02:20 PM
john1782's Avatar
john1782
Default 02 R/T Transmission question
I'm almost at the end of the Auto-rx cleaning phase and will be having the transmission flushed. I was curious as to wether the transmission has a filter to be replaced or just a screen that'll need cleaned off?
Thanks
Old Nov 22, 2007 | 02:34 AM
adio405's Avatar
adio405
Default RE: 02 R/T Transmission question
I have an 02 coupe with the 2.4 and my trans-axle has a filter. I would assume yours does to.
Old Nov 22, 2007 | 05:37 AM
nate_0022's Avatar
nate_0022
We have filters.I was told they weren't really neccessary to change?
Old Nov 22, 2007 | 08:30 AM
StratRat62's Avatar
StratRat62
The filters in the Mitsu automatic transmission are difficult to get to and not necessary to change unless a rebuild is done. The fluid can be changed but if you do be sure you use the right tranny fluid to refill. It is not a standard fluid and standard fluid will not work properly.
