Mystery water leak
Old Nov 18, 2007 | 08:56 PM
akbrewer's Avatar
akbrewer
Default Mystery water leak
We have a 2001 Dodge Stratus SE 4 dour coupe with a sun roof. Just recently thefloor behind the driver's side seat has been filled with water whenever it rains, almost to the point it is overflowing with water under the driver's seat. We dry it up and the next time it rains it happens again. I've sat in the car while it's raining and can see no drips from the sun roof, or from the passenger door or window seals. In factanything above the carpeted floor area is nice and dry. My wife thinks that the water is splashing up under the car while driving but I've looked under the car and can't see any obvious holes or missing components. I did find a floor heater vent located under the driver's seat but it seems dry unless water is tricklingout of it on occasion, but then it would stand to reason that both back seat floors would be wet. Any ideas on what might be causing this?
Old Nov 18, 2007 | 10:01 PM
nate_0022's Avatar
nate_0022
Default RE: Mystery water leak
AC lines might be clogged?
Old Nov 19, 2007 | 10:35 AM
Scamz's Avatar
Scamz
hey i have a 2001 r/t n i had gthe same problem, jsut my driver side would become soakin wet when it rained, had it checked out turns out there was a leak in the firewall, and they had to seal it up n stuff, was a big project, but knew a mechanic so got a good price, might need to have that checked out caseu i couldnt find a leak anywhere either
Old Nov 19, 2007 | 11:25 PM
frankie12's Avatar
frankie12
I agree with Nate, you should have your AC lines checked.
