check engine light is on and Transmission is messing up.
Old Dec 12, 2007 | 12:48 AM
ravenv12's Avatar
ravenv12
Default check engine light is on and Transmission is messing up.
check engine light is on and Transmission is messing up. speedometer is working but RPM gauge does not work all the time , Transmission works sometimes but only if you cut the car off and cut it back on Transmission works . The car won't shift out of 2nd gear. The Check Engine light is on.
something behind the engine block is causing it to smoke , I need to know what is behind the engine block. that oil could leak out from.
I took the car to one of the shops Here the codes were
47 solenoid switch valve stuck in low range
38 lockup control
74 calculated oil temperture in use
35 loss of prime
24 low-reverse pressure switch circuit
Old Jan 9, 2008 | 10:21 PM
gjp's Avatar
gjp
Default RE: check engine light is on and Transmission is messing up.
what year is it
