Transmission problem!
Old Jan 1, 2008 | 01:00 PM
Spucknit's Avatar
Spucknit
Default Transmission problem!
My wife's 2002 stratus started shifting hard at about 38,000 miles. I noticed a small leak from the gasket, tightened the loose bolts, toppped of the fluid and was well. Then at 42,000 it started shifting hard again. I went to replace the filter and fluid and found something that bothers me. While cleaning the magnet in the bottom of the pan I found an E-clip. It's about 1/4" in diameter, and there were no signs of it coming off anything visible with the pan off so I replaced the filter, gasket, fluid with ATF+4 and took out for a test run. Now the tranny seems fine other than while down shifting between third and second. Only those gears and only while downshifting. I'm completely stumped.
Old Jan 17, 2008 | 08:49 PM
gradedgraydad's Avatar
gradedgraydad
Default RE: Transmission problem!
1. Isn't the car still under warrantee?
2. Look on-line for an exploded view of your transmission and see if you can identify the clip.
3. Take the clip to a transmission repair place and ask them. Tell them it's a friend's car and they're out of town or something.
