2000 Stratus stock alarm
My 2000 stratus's stock alarm is cutting out the starter making it not start. I have a remote but that isn't turning the alarm off either. All the dash lights and the flashers flash just like it is when the alarm is activated. No siren blast though. What I would like to know is how I can disconnect this alarm if that is the problem or maybe I am missing it all together. Any help would be appreciated.
I need Help too,I have a 1996 Stratus 2.4L that I bought for my daughter, the odometer and tach wasn't working but the Speedo was. I was told it was a bad dash cluster. I put a different one from the same year and the odometer did work on that one but the Speedo and tach didn't, on both dashes the gas and oil gauge did work. I was told to check the circuit board andfor somesoldering breaks.
I did re solder some maybe bad looking ones. Nothing made either dash work completely. I then reinstalled the factory cluster and my daughter headed back home to go to work 200 miles away. She stopped at service center for coffee and when she came out to start the car the engine fired and the headlights and dome lights flashed and then the engine died. Each time she tried to start it the same thing happen, started and shut down. I drove down and un hooked the battery for 30 minutes to reset the computer, no good same thing. I thought the car might of had a factory alarm.I had it to towed($256) to a Dodge dealer in MA who then told me the car didn't have a factory alarm and they needed $1600.00 up front to start replacing parts with no guarantee what the final bill would be. He said a $150.00 for just looking at which I paid. I then said stop and I will tow the car back to Maine.
Does anyone have any idea what happened and how can I repair the car, anyone had the same troubles? I would deeply appreciate any help on this.
Thank You Very Much[/align]
