98 stratus problem?
i have a 98 stratus 2.5 v6. this went from a supposedly bad fuel pump to::: now i have new plugs,cap,rotor,egr,pcv,battery,coolant temp sensor,reman distributor,fuel pump,fuel filter. and this car still isn't right. it'll start right off but then acts like no power ,like running on 3 cylinders. it doesn't miss, iget no codes either. i had it in the shop and the owner said all he found with his $6000.00 scan tool was the timing seemed to jump a little when he drove it. he said flow test showed cat converter was ok and he said all sensors were ok. he said he thought it was one of 3 things, distributor,computer or timing belt,which he said timing marks were right on. this car does have 140,000 miles on it and up until the fuel issue, it ran great. i'm putting a brand new distributor,timing belt and water pump in this car this weekend. anyone have any suggestions or comments on this. thanks Randy[/align]
