allseasons put on alloy rim now noise front right!
Old Apr 25, 2008 | 03:14 PM
methodman1992's Avatar
methodman1992
Default allseasons put on alloy rim now noise front right!
Here is what happened! i grabbed these rims for $40 from a good friend who had them on his corolla, got new ones so where just sitting there! i put my michelin destinys on them and had them put on and balenced well went to move it back and she moved 1/2ft then stoped! the corner area was digging into the rim! so put the snows back on and when i got home ground those edges off! now they clear nicely! well on the drive home! i noticed a roar coming from front right! so pulled over half way and checked things out! well there is nothing i can see wrong! anyways it doesn't make the noise under 5kph and gets louder the faster i go! not increasing after 140kph! please help! im thinking balljoint!
Old Apr 25, 2008 | 08:51 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: allseasons put on alloy rim now noise front right!
did you torque the wheels on properly ???
overtightening can warp the rotors ....
other thing can be the wheel bearing/hub assembly
Old Apr 25, 2008 | 09:21 PM
methodman1992
yeah they are tourqued to 110 as acording! yeah thought that!
