transmission kickdown problem
Old Apr 27, 2008 | 05:04 PM
stryker77's Avatar
stryker77
Default transmission kickdown problem
I have a 2005 stratus and am experiencing some problems with shifting. Got a problem when I shift from 1st-2nd gear (it seems to "jerk" when it catches), and then when I'm on the highway doing 75 and try to accelerate and rpms get to about 4500 or so, it makes a "grinding" noise when I release the gas pedal.
Now, I'm planning a road trip in a couple of weeks, and need to find out what the problem is. Any ideas?
Old Apr 27, 2008 | 08:27 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: transmission kickdown problem
Have you checked fluid level ???
Old Apr 27, 2008 | 09:31 PM
stryker77's Avatar
stryker77
yeah, I already checked the tranny fluid level and it was good. What else do you think it could be?
Old Jun 9, 2008 | 05:08 AM
stryker77's Avatar
stryker77
Does anyone have any ideas?
Old Jul 1, 2008 | 01:53 AM
JayD's Avatar
JayD
when my auto trans changes from 1st to 2nd when I am getting on it, it will jerk but not so much like a ****ty trans... just like a perfect drop from 1st to 2nd rpm wise.. if i am driving at 75 mph my car will kick down into 3rd gear a lot of the time.. no grinding but will drop down into 3rd.. but it doesnt do it much anymore at all.. not sure I also had my tranny flushed about 3k miles ago..
Old Jul 1, 2008 | 12:14 PM
Bots10's Avatar
Bots10
Is it an standard or automatic? Might want to check the clutch. Sounds like it might be either a bad pressure plate or throw out bareing.
