2004 Stratus Drivers Window works intermitently
Old May 21, 2008 | 10:15 AM
nichan's Avatar
nichan
Default 2004 Stratus Drivers Window works intermitently
Hi All
I've got a 2004 Stratus that the drivers side window is working sporadically, if it is hot out the window will go down and up (slowly), if it's cold the window does not move at all. Could this be motor or regulator related.
Thanks
Old May 21, 2008 | 03:41 PM
jeffham222's Avatar
jeffham222
Default RE: 2004 Stratus Drivers Window works intermitently
check relays... more than likely you just have some relays sticking... At least this is where I would start. Relays are cheap and easy to replace. Best of luck!!
Old May 21, 2008 | 11:53 PM
02sxtstrat's Avatar
02sxtstrat
Have the same problem with my rear window in my 02 stratus. Where are the relays located at?
Old May 23, 2008 | 02:09 PM
gpg's Avatar
gpg
They'll be in the fuse box in your engine. You'll see a black box with a plastic cover. Pop off the lid, and then read the map until you find them
