Radiator Fans and AC Compress do not run
Old May 22, 2008 | 10:30 PM
craveyj's Avatar
craveyj
Default Radiator Fans and AC Compress do not run
I have a 2000 Dodge Stratus ES 2.5L V6 184K
Car startsbut both radiator cooling fans and AC compressor do not run.
Car shuts down and does not start. (no spark to spark plugs) I have wait for a day then it will start.
Tested fan relays andcheck fuses. everythings appears ok.
Both radiator fans run if you manually close the relays.
Replaced Coolant tempeture sensor.
Does anyone know what siginal does pcm require to run the radiator cooling fans
