fan speeds on climate control-1+2 inop, 3+4 ok
Old Jul 14, 2008 | 10:39 AM
detroitdieselman's Avatar
detroitdieselman
Default fan speeds on climate control-1+2 inop, 3+4 ok
Do you folks know if there is a board somewhere in the car with a bank of resistors that work with the fan speed ****? The **** is ok, I tested it. I don`t have fan speeds 1 or 2, but 3 and 4 work ok. The car is an 01. Thanks in advance
Doug
Old Jul 14, 2008 | 12:36 PM
craveyj's Avatar
craveyj
Default RE: fan speeds on climate control-1+2 inop, 3+4 ok
Replace your ignition switch. I had the same issue on a 2000 dodge stratus with 2.5l. I have no ac blower fan speeds and the air bag light was on. I replace the ignition switch it resolved both issues.
Old Jul 14, 2008 | 05:40 PM
detroitdieselman
I found a resistor board in the ductwork that looked like a credit card with a connector on one end. That was the problem. $50 bucks at dodge, $26 at NAPA.
Thanks
Doug
