Car maintenance
Old Jan 13, 2009 | 08:17 PM
Linkinxp's Avatar
Linkinxp
Arrow Car maintenance
Hello again! .... I am a little bit worried about my car maintenance, it has more than 174.000 miles and i would like to know what should i replace or check to keep my car running
it is a Dodge Stratus 1997 2.4 DOHC .. Here its what i have changed:
Water Pump
Tires
Brakes
Air Intake
Oil every 3000 miles
Old Jan 13, 2009 | 08:22 PM
bad venge's Avatar
bad venge
Section Moderator
Timing belt and waterpump are WAY overdue
Old Jan 13, 2009 | 08:23 PM
Linkinxp's Avatar
Linkinxp
I changed both when it had around 150.000
Old Jan 14, 2009 | 08:49 AM
bad venge's Avatar
bad venge
Section Moderator
wasn't on your list ...
Old Jan 14, 2009 | 09:09 AM
Linkinxp's Avatar
Linkinxp
I'm sorry about that, anything else i should change?
besides
Spark Plugs and cables
Valve Gasket maybe?
Old Jan 14, 2009 | 09:58 AM
bad venge's Avatar
bad venge
Section Moderator
unless you have oil pooling in the plugs the gasket is OK...
Plug wires and plugs are good idea
