99 Startus rough idling ... help
Old Feb 25, 2005 | 06:01 PM
gmadigyal's Avatar
gmadigyal
Default 99 Startus rough idling ... help
Helo,
I am not so good in car tech.
Few days ago, I got the broken engine mounts replaced and Cam shaft sensor.
Then, I notice that the car jerks when idling. Looks like it is missing fuel or
not firing properly. It was worse when I reverse, the car vibrates more
when I apply brakes in reverse.
I took it to the dealer and mech advised to changing all spark plugs.
But, still the car keeps doing this ..........and no engine codes/warnings.
I dont know what to expect next when I take the car back to the mech.
Appreciate if some one can advise on what to check and expect.
Thanks
Old Mar 12, 2005 | 03:51 PM
PearlStealthRT_TT's Avatar
PearlStealthRT_TT
Default RE: 99 Startus rough idling ... help
smell the exhaust...head gasket maybe??
Old Mar 17, 2005 | 01:35 AM
dishdude's Avatar
dishdude
check the egr.. your supposed to be getting a code.. but nothing is perfect.. unplug the hose between the 2 pieces of the egr.. see if it idles better
Old Apr 25, 2005 | 03:38 PM
gmadigyal's Avatar
gmadigyal
I tried to unplug both the rubber hoses between the two parts of the EGR...unfortunately it didnt change anything...
Hope some one has other ideas to try to figure out the mysterious right cause....
