Leaks around tranny/block area
Old Mar 16, 2009 | 09:28 AM
always faster's Avatar
always faster
Default Leaks around tranny/block area
I, im a newbie here.I got 98 2.4 stratus.Yesterday i took off my winter tires and wheel to install my summer one.I change those quickly and took it for a drive.I realise that one of my wheel bearing was shot(front pass side) so i took the car home and found a black spot in my driveway.
I then check the car and saw that it was leaking fluid between the transmission and the engine block(everything is wet).The trans fluid is ok,the master fluid is ok,the power steering is ok and i also checked the cooling fluid and its ok with no oil in it.But there was a lot of oil missing in the engine so its engine oil.The car run fine without overheating but it leaks oil quite a bit.
So before pulling off the trans because my first thougt is that the crank seal is shot,should i checked something else that could be the source of the problem.Something maybe that someone have already experience.
Thank you and sorry for my bad english
Old Mar 20, 2009 | 10:17 PM
tomthedog's Avatar
tomthedog
oil filter.
then wash the engine of all the built up gunk. then look for fresh oil.
Old Mar 21, 2009 | 04:31 AM
always faster
Originally Posted by tomthedog
oil filter.
So your suggesting that it could be the oil filter or oil filter housing???
I will change the oil and clean everything underneath the engine and look for some leaks.
Thanks
Old Mar 30, 2009 | 09:10 PM
xCRISOMX's Avatar
xCRISOMX
hey man i got a 98 also mine was a swap motor for racing reasons check valve cover gasket or the hose oil pump in the back of the motor same thing happened to me change oil pump and vavle cover and gasket and it was fine also to help better problem u might have a small pin hole that you or any one might not fix by lucust oil treatment and there you go
Old Mar 31, 2009 | 08:56 AM
always faster
Yesterday i ve washed the back of the engine with brake cleaner but it was really seems to be coming from the back of the head near the gasket.So ill drive it for 2-3 days and check it back.
Thanks
Old Apr 1, 2009 | 07:50 PM
tomthedog's Avatar
tomthedog
if it's the top of the head, could just be the valve cover gasket, no big deal to replace. if it's the head gasket, it's a bit more in depth.
let us know.
